  • 1.  Prevent multiple Dashboard / command line options
    Posted 08-17-2016 14:12
    two questions, possibly vaguely related...
    Is there a way to prevent multiple instance of Dashboard from running. I find I get Java errors related to sockets in use if a second instance of my Dashboard is opened - I'd like to catch these error gracefully, or prevent two instances of the same Dashboard being opened.
    Are there any command line options I can add to a desktop shortcut to specify which .grid file to open, and to make it open in full screen mode.
    Many thanks,
    Martin
  • 2.  RE: Prevent multiple Dashboard / command line options
    Posted 08-17-2016 17:28
    Hi Martin.
    There is not currently a solution to prevent multiple instances of DashBoard from running. In some cases, it is necessary to have them running as individual DashBoard instances have a limit on how much memory they are allowed to use and it is possible that a customer's requirements may exceed them if multiple [very] large panels are used.
    One quick solution to make DashBoard launch with a specific *.grid file and remember its fullscreen state is to save a layout (SHIFT + F10) with the grid file open and DashBoard in fullscreen mode. You can then create a shortcut and add -layout LAYOUT NAME as a command line option to the shortcut (just make sure your layout name has no spaces in it). There may be other options that will work for you but I think this one gets the closest to what you're after.
    James
  • 3.  RE: Prevent multiple Dashboard / command line options
    Posted 08-18-2016 16:24
    Hi James,
    the Layout trick works brilliantly, thank you. I'll try to build something into my code that can trap the multiple instance problem.
    thanks again,
    Martin
  • 4.  RE: Prevent multiple Dashboard / command line options
    Posted 08-18-2016 17:49
    One thing we've seen people do is check for the presence of a file on startup and, if it is there, show a "DB ALREADY RUNNING" screen. You can create an onclose handler to delete the file when DashBoard shuts down. Naturally, you'd also need to have a "LOAD ANYHOW" option in case DashBoard/the PC was not properly shut-down).
  • 5.  RE: Prevent multiple Dashboard / command line options
    Posted 08-25-2016 16:36
    James, I missed your post. Thanks, this sounds like a great way to detect multiple instances running, it will be in my finished panel!
