  • 1.  Card Inventory
    Posted 11-30-2016 13:48
    Is there a way to report an inventory of card information in DashBoard? We have many OG frames that are fully loaded with cards. Managing manufacturers, model numbers, serial numbers, and firmware versions with an inventory list would be very beneficial. This could be exported as a PDF or CSV or just displayed in a window allowing you to open cards from there. Another helpful export would be a CSV of all settings on identical modeled cards for quick comparison. Again, this could be a popup window with an option to copy settings from one card to many.
  • 2.  RE: Card Inventory
    Posted 11-30-2016 14:50
    Hi Matthew.
    DashBoard does not have the ability to export as a CSV but can export all card and frame information to XML.Card data can also be copied to other compatible cards either from a file or from a live device.
    To save a card or a frame, right-click on the one you want and select "Save configuration to file".
    To save a collection of frames, use the DashBoard Advanced Tree View and drag all of the frames you wish to include into a folder. Then, right-click on the folder and select "Save configuration to file"
    All of the above result in XML-formatted files containing the information you are looking for.
    Cheers.
    James
