Yes James, I mean the text content of a node.
I'm sure I have the nodes since I get the correct amount of nodes returned by getElementsByTagName. Still I keep getting the "getTextContent is not defined" message in the debugger.
Here's some of the code:
var XML = ogscript.parseXML('file');
if (XML == null) {
ogscript.debug('Failed to read file');
} else {
ogscript.debug('Parsing XML');
var games = XML.getElementsByTagName('Played');
ogscript.debug("items found by getElementsByTagName: " + games.length);
params.setValue('found', 0, games.length);
for (i = 0; i < games.length; i++) {
var node = games.item(i);
var gamesPlayed = getTextContent(node, 'Played');
params.setValue('matchesArray', i, gamesPlayed);
Shouldn't getTextContent now run on all of the elements returned by getElementsByTagName?
Any help would be appreciated,
T
