A new version of DashBoard V6.0 Beta is available.
It can be downloaded from:
http://www.rossvideo.com/terminal-equipment/opengear/control-monitoring/dashboard-beta.html
The change list is:
OS X - We now ship the OS X version of DashBoard with an embedded JRE (Jave RunTime Environment). Users no longer have to uninstall previous versions of DashBoard manually or install Java manually.
New 'List' Widget - A new 'list' widget type is available to view parameters with choice constraints.
Color Chooser preset colours - Some of the color picker tool presets at the bottom of the widget were giving the wrong color. This has been corrected.
openFile item added to main DashBoard menu - The openFile item allows the user the ability browse the local file system for a .grid file to open.
.grid files now save comments - Previous versions of DashBoard would remove XML style comments
Added params.getParam('[context id]', OID, element) - New ogScript function that returns a parameter context. This parameter context allows for reading and setting of parameter values.
Lots of improvements on OS X - DashBoard 6.0 Beta is now available on OS/X. Many improvements and bug fixes for the OS/X version have been addressed.
Added 'widget root'/Lock Contents attribute to Canvas widgets - A new checkbox 'Lock Contents(widget root) can now be set in the 'Abs Attributes' editor Tab.
Bug Fixes - Numerous bug fixes throughout the DashBoard CustomPanel interface.
Troy.
