  • 1.  Dashboard Carbonite
    Posted 07-24-2013 14:37
    I've just managed to get my fancy new Dashboard BETA setup and working correctly. I've read through all the documentation that's available and started building a custom panel.
    I have my Xpression connected up in the mix and I've created some buttons to take items and clear frame buffers. The problem I've run into is trying to set up the task of activating the keyer, on the desk, at the same time as taking the graphic in the Xpression sequencer. Well, to be honest, I can't get the KEYCUT [MLE]:[keyer] function to work on it's own.
    The documentation suggested that not all functions would work correctly and I'm wondering if this is one of them.
    Also, When dragging a single button from the buses tab, why does it not copy the attributes for the original button?
    For example, button 1 (input 1) on MLE 2 often changes to AUX 8 when dragged across to a new custom panel.
  • 2.  RE: Dashboard Carbonite
    Posted 07-25-2013 16:33
    Hi Matthew,
    I'll contact you privately to explore this problem.
    Best,
    John
