  • 1.  Rosstalk and SendMessage with callback issue
    Posted 10-22-2014 18:09
    I'm trying to put in place a tcp communication using rosstalk and my device.
    I'm using the sendmessage method with callback. The callback function is the one supposed to give me the response of my device a a tcp message.
    The problem is that the response is always a null string.
    I was wondering if there is a bug in Dashboard or if i'm doing something wrong.
    The code looks like this:
    function callback(success, sentData, resultString, exception)
    ogscript.debug("TCP result: " + resultString);
    var ip = params.getValue(0xC,0);
    var port = params.getValue(0xD,0);
    rosstalk.sendMessage(ip, port, message, callback);//Send message to external device
    I would appreciate if somebody could shed some light on this issue.
    Bruno
  • 2.  RE: Rosstalk and SendMessage with callback issue
    Posted 10-23-2014 03:15
    Hi Bruno.
    Unfortunately, the rosstalk.sendMessage will typically terminate the message after it has been sent without waiting for a response. The only exception to this is if the message sent ends with a "?" character. This is because rosstalk.sendMessage was designed for "fire and forget" messaging.
    If you need to engage in a multi-message conversation over TCP/IP, one option you have is to use a tag (which can act as a server or connect as a client).
    Hope this helps.
    James
  • 3.  RE: Rosstalk and SendMessage with callback issue
    Posted 10-23-2014 15:07
    Thanks James for the quick answer.
    Bruno
  • 4.  RE: Rosstalk and SendMessage with callback issue
    Posted 10-23-2014 15:22
    You're welcome - please note that the post should have said " tag" (the forum originally hid the tag because I hadn't escaped the brackets).
    If you have any issues using the listener, please post back and we'll do what we can to get you sorted.
    James
