Is the switch connected to the router? Do both of your devices have valid IPs? Your switch won't do DHCP for the switcher and blackstorm server so unless you've manually assigned them IPs, they may not be seeing a valid network or each other.
Connect your switch to the router and verify that both devices are assigned valid IP addresses. Otherwise manually assign these addresses yourself.
