  • 1.  Timer Format
    Posted 10-02-2014 03:52
    I've been working on creating a simple score graphic controller for Xpression. In the past, we've just been using Xpresison's timer widget, and it displayed minutes, seconds and milliseconds. (N:SS.ZZ) Milliseconds only showed 2 digits
    However, in Dashboard, it seems like the milliseconds will only show as 3 digits. Is there any way to get rid of that last digit? Or is there another method altogether that I should be using to drive timers in Xpression through dashboard?
    Any help would be appreciated, thanks
  • 2.  RE: Timer Format
    Posted 10-02-2014 14:52
    In Xpression you can use Visual Logic to strip off the last character. You would still put out all 3 Digits in Dashboard but in the end you would only display the ones you want
