  • 1.  automatic suffix
    Posted 01-19-2015 20:43
    Hi there, I'm trying to write a script that will automatically add a suffix into a text field. Here's what I've got so far, based on Javascript, but I get an error that says it can't find the "indexOf" function.
    var self = this.getValue();
    // if text string already contains '%', then we're done
    if (this.indexOf("%") >= 0){
    ogscript.debug('done');
    // otherwise, add the '%'
    else {this.setValue(self + '%');
    What am I missing here?
  • 2.  RE: automatic suffix
    Posted 01-19-2015 20:47
    "this" is a Param object and has no indexOf function.
    Strings objects do have that function.
    `var self = this.getValue();
    if (self .indexOf("%") >= 0){
