  • 1.  Using only one Xpression template
    Posted 05-03-2017 15:42
    Hi Guys
    I would just like to find out if it is possible to use only one Xpression template using dashboard?
    For instance, if I have more than 1 match on a day, is it possible to datalinq my dashboard to one Xpression template opposed to creating two-year sheets per match?
    I hope this makes sense
    Cheers
  • 2.  RE: Using only one Xpression template
    Posted 05-09-2017 21:35
    Hi Dennis.
    If you are feeding the template through DashBoard's DataLinq, the template should be updating the values you're sending through DataLinq as soon as you change them.
    If you are looking to have different values in the same template simultaneously, I'm afraid that's not possible.
    James
  • 3.  RE: Using only one Xpression template
    Posted 05-10-2017 08:01
    Hi James
    Thank you for the feedbac"‹k.
    Regards
    Dennis Hall
