  • 1.  Using SFTP in Dashboard
    Posted 09-19-2017 11:51
    Hi
    Is it possible to use SFTP in Dashboard? I need to pull files down and the client requires a secure connection.
    Simon
  • 2.  RE: Using SFTP in Dashboard
    Posted 09-19-2017 14:00
    Hi Simon.
    DashBoard does not currently contain an SFTP library. There is a technique we can use in DashBoard launch an external process that might help. You could use it to fire-up command line tool to do the SFTP and make use of it in your DashBoard application.
    Contact me directly (jpeltzer@rossvideo.com) and I can send you an example of how to do this.
    James
