Sorry for the delayed response.
The easiest way to duplicate a parameter would be to go into the Parameters dialog select the parameter you want to duplicate, change the OID to something else, and select "Commit Changes". You can do this for each one.
You could also copy/paste the XML tag (the one inside the ... tags) and change the OID to something else there.
