  • 1.  On keypress
    Posted 02-11-2015 17:52
    Is there a way to use keystrokes to control buttons in Dashboard? Specifically, I have an integer choice parameter using the toggle button widget, is it possible to use space bar, for example, to change the toggle state?
  • 2.  RE: On keypress
    Posted 02-13-2015 14:56
    You can see an example of how to do this if you open DashBoard's help:
    Help : Help Contents
    Do a search for "GPI" and you'll see "Triggering Tasks Externally" appear in the search results.
    That will give you an example of how to do this.
    Following the steps in that section of the manual will get you closer than any example I could try to post here.
