  • 1.  Can't Open Grid File
    Posted 11-18-2015 18:07
    My control computer had to be restarted due to a power issue last week and I can't open the custom Dashboard panel I've been using to control my switcher. Here's the error message I get:
    java.lang.NullPointException
    I recently upgraded to Dashboard 7 but it was running fine until last Friday when the computer had to be restarted. Any help would be greatly appreciated.
  • 2.  RE: Can't Open Grid File
    Posted 11-18-2015 21:14
    Have you tried opening your panel in a text editor to see if something has gone wrong with it?
    DashBoard makes a backup of files as it writes to them and while they are being saved. If your file is corrupted, look in the same folder for a *.bak copy of your file.
  • 3.  RE: Can't Open Grid File
    Posted 11-19-2015 13:51
    That was it. Thank you!
