  • 1.  Documentation on Status Dot?
    Posted 10-10-2018 18:51
    I'm messing around with Dashboard trying to setup a way to have one dashboard monitor another via rosstalk commands and status dot parameters. I tried looking around and I don't really see a whole lot of documentation on how they work as far as setting the values and colors of the dots. Any idea on how I can program these to change colors based on status updates?
    I can drag and drop from a Carbonite dashboard panel but it doesn't really give me a whole lot of information on how the status dot is actually controlled.
  • 2.  RE: Documentation on Status Dot?
    Posted 10-10-2018 19:07
    Nevermind. I figured it out. You set the value of the dot to the hex color value (i.e. "") and it updates accordingly. I was looking at outdated documentation.
  • 3.  RE: Documentation on Status Dot?
    Posted 10-12-2018 08:22
    Ohhh ohhh ohhh! I know this one!
    I knew I had seen this somewhere in DashBoard U, in this video!
    https://www.rossvideo.com/gallery/in...-to-scripting/
    I've added a simple DashBoard below with 3 buttons changing the value of your LED/Status Dot. It's simply setting the value of the parameter to '' with the 00 pairs as hex values of the RGB value.
    Enjoy! :D
    <abs contexttype="opengear" gridsize="20" id="_top">
       <meta>
          <params>
             <param access="1" maxlength="0" name="LED" oid="LED" type="STRING" value="&lt;#ff0000&gt;" widget="dot"/>
          </params>
       </meta>
       <param expand="true" height="80" left="220" oid="LED" top="160" width="40"/>
       <button buttontype="push" height="80" left="260" name="RED" top="160" width="140">
          <task tasktype="ogscript">params.setValue('LED', 0, '&lt;#ff0000&gt;');</task>
       </button>
       <button buttontype="push" height="80" left="420" name="YELLOW" top="160" width="140">
          <task tasktype="ogscript">params.setValue('LED', 0, '&lt;#ffff00&gt;');</task>
       </button>
       <button buttontype="push" height="80" left="580" name="GREEN" top="160" width="140">
          <task tasktype="ogscript">params.setValue('LED', 0, '&lt;#00ff00&gt;');</task>
       </button>
    But yes... I didnt find any good information on how this was done either, I just remember I had seen it somewhere...
  • 4.  RE: Documentation on Status Dot?
    Posted 10-12-2018 16:58
    Ah, that did it. Thanks!
