Hmmm... I think I may have found a bug?
I made a custom control on the Carbonite that fires a play command to the 3Play, has a Hold, and then fires a stop command, essentially making a toggle button to pause the 3play. It works fine when I trigger it on the Carbonite, but when I trigger it via GPI (through analog GPI on the back of the Carbonite with a push button switch) it seems like it will play the first part of the macro fine (up to the hold), but when I hit the switch again it runs the macro from the beginning up until the hold again... never getting to the second half of the macro.
Is this a known issue with GPIs and firing custom control macros?
