  • 1.  Visual Scripting questions.
    Posted 02-06-2018 15:35
    Using visual scripting, how do you indicate the index?
    params.getValue([oid], [index]);
    also using visual scripting, how do you specify the OID using a variable?
    params.getValueAsString('count_1027', 0 params.getValueAsString(count_1027, 0
  • 2.  RE: Visual Scripting questions.
    Posted 02-12-2018 14:55
    Hi @dbartlett.
    This appears to be an issue with the implementation of this Visual Logic block.
    I'd recommend manually-scripting things when you need to get a value as a string at the moment.
    Very sorry for the inconvenience - we can let you know when we have an updated beta build of DashBoard 8.4 available that addresses this issue.
    James
