  • 1.  Dashboard Integration w/ Older XPression Version
    Posted 02-08-2018 16:30
    I have XPression Studio v5.0, will that still be compatible with a dashboard panel to run my score bug? Also where can I find the minimum laptop requirements for achieving this from a remote laptop?
    Sorry if these answers were somewhere in the forum, I searched but didn't find similar questions.
    Thanks all!
  • 2.  RE: Dashboard Integration w/ Older XPression Version
    Posted 02-08-2018 16:42
    For the XPression side of things, you'll want to post over on their community page to find out the minimum version of XPression that supports whatever commands you're trying to use. DashBoard uses RossTalk to do things like bring Take IDs on air. If you're talking about using DataLinq Server, you'll want to find out which version supports DashBoard DataLinq Connection though, if your version is too old, you could also use DataLinq's XML reader and use an "external XML data source" for your custom panel.
    These are the minimum system requirements for running DashBoard: System Requirements
    Refer to the following sections for information on the system requirements for DashBoard.
    Microsoft® Windows® 10, Windows® 8, or Windows® 7 Systems
    The following are the minimum requirements when installing DashBoard on a Microsoft® Windows® system:
    "¢32-bit or 64-bit configurations
    "¢Intel® Pentium 4, 1.6GHz (Intel® Core™ 2 Duo recommended)
    "¢Minimum 2GB RAM (4GB or more recommended)
    "¢300MB available in HD space
    "¢Microsoft® Internet Explorer® version 8 (minimum)
    Note: If you are running DashBoard on a Microsoft® Surface Pro®, you must use a physical keyboard or enable the standard keyboard layout.
    Apple Mac® OS X 10.8.3 (or higher) Systems (64bit)
    The following are the minimum requirements when installing DashBoard on a Mac® OS system:
    "¢64-bit configuration only
    "¢Intel® processor
    "¢300MB available HD space
    "¢Mac® Safari®
    Linux® Fedora® 18 (or higher) Systems
    The following are the minimum requirements when installing DashBoard on a Linux® system:
    "¢Mozilla 1.4 GTK2 - 1.7.x GTK2, XULRunner 1.8.x - 1.9.x, 3.6.x and 10.x (but not 2.x nor 4.x - 9.x), WebKitGTK+ 1.2.x and newer
    "¢Version 2.2.1 GTK+ widget toolkit and associated libraries (GLib, Pango) are required
    Hope that helps.
    James
  • 3.  RE: Dashboard Integration w/ Older XPression Version
    Posted 02-08-2018 16:49
    Great, thank you!
