No, no reply except for yours. I did manage to get past my urgent situation last week. But this has been an ongoing issue for us: inconsistent behavior when uploading/importing files to the BlackStorm server. Sometimes it works, sometimes it fails. Sometimes a file will appear to be importing, but then never shows up in the media bins.
The only thing I noticed that I changed recently during my urgent situation was that the failed FTP uploads were rendered with 1 keyframe every 60 frames (house format is 720p, 59.94 fps), using Animation codec at 75% quality. When I re-rendered (after several attempts), I finally changed the setting back to keyframe every frame, the file successfully uploaded.
Any thoughts on all of this? Is there something I am not doing that should be a part of the upload/import process?
Thanks,
Shane
