  • 1.  Ember+ from Dashboard
    Posted 10-15-2016 22:45
    Just wondered if anyone here has any experience sending/receiving ember+ commands to external gear from Dashboard? Could be useful for controlling external devices directly from Dashboard as ember+ normally is injected to the hardware directly without going via management software.
  • 2.  RE: Ember+ from Dashboard
    Posted 10-17-2016 15:48
    I'm not aware of any examples of this but, in general, if it can be controlled by TCP/IP or UDP messages, there is a way to make DashBoard talk to it.
    If you have an example of the Ember+ commands, protocol, and port you need to send to we can generally provide you with a snippet of ogScript code to show you how to send it through a Custom Panel.
