  • 1.  communication between 2 grids files
    Posted 07-17-2015 18:22
    Is it possible to call a function implemented in a grid file from another grid file?
    Bruno
  • 2.  RE: communication between 2 grids files
    Posted 07-17-2015 19:15
    Not directly, no.
    You could use the GPI Trigger feature to 'press a button' in a different panel.
    `ogscript.fireGPI('[GPI]', '[state]', true);` will fire a "GPI Trigger" across all open panels (the true at the end is the flag to fire it globally).
    If you attach a trigger to a button or label, (see Trigger ID field above each button's task list), you can trigger them this way.
  • 3.  RE: communication between 2 grids files
    Posted 07-21-2015 13:59
    Thanks.
    Is it possible to share variables between 2 grid files?
    Bruno
