  • 1.  Triggering a Xpression Media Wipe and ME Transition
    Posted 11-02-2018 21:11
    Hi All,
    I'm pretty new to creating custom controls within Dashboard so bear with me. I've set up a CC to trigger an animated wipe from Xpression while also triggering a transition on my Carbonite(cam switch on ME2). What i'd like to know is if there is a way to delay the transition on the Carbonite to snyc up with my animated wipe. As it is now, it always performs the transition immediately at the same time the wipe flies in. I know i can offset the Carbonite transition easily using Media Manager but we would be changing the wipes constantly throughout the day so it would be preferable to be able to do this using a single CC. Any help would be appreciated.
  • 2.  RE: Triggering a Xpression Media Wipe and ME Transition
    Posted 11-02-2018 21:14
    All you have to do is add a pause to the custom control. On the shot box editor, I believe it is listed under "special."
  • 3.  RE: Triggering a Xpression Media Wipe and ME Transition
    Posted 11-02-2018 22:16
