  • 1.  Dashboard and Animation Controllers
    Posted 07-24-2015 15:57
    I was wondering if it is possible to have Dashboard trigger multiple animation controllers in a single Xpression Scene.
  • 2.  RE: Dashboard and Animation Controllers
    Posted 07-25-2015 15:18
    Try using the keyboard mapping.
    Make a project map where you add a script item. Make the script trigger the animation controllers. Then assign a RossTalk/smartGPI to it.
    Make sure you had already setup a RossTalk/SmartGPI board under the hardware configuration (which should be done if your already using dashboard) now you can trigger the controllers from that GPI assignment.
    Also by using the project assignments section you will not have to worry that taking that project to another XPression will also require bringing a keyboard assignments file as well.
