  • 1.  Graphite: Storing MiniME banks
    Posted 01-07-2018 02:00
    In Live Assist > Memory > Store Mini ME att the top, I can't seem to deactivate ME1 or ME2. I'm trying to save a memory just for MiniME4 but if I try clicking off ME1 or ME2 in the Inclusions section, the other ME turns on. Ex: With ME1 and ME2 turned on, clicking ME1 will turn off ME1, clicking ME2 will turn off ME2 but turns ME1 back on. Vice versa if I go in the other order.
    Is this a bug? Am I always storing a ME bank when storing a MiniME or Multiscreen bank?
  • 2.  RE: Graphite: Storing MiniME banks
    Posted 01-07-2018 04:48
    I was able to access the physical Carbonite panel and when I unlit ME1 and ME2 from there, Dashboard then followed. Using Dashboard, I was only able to replicate the issue once out of a series of random attempts. It also took a Carbonite panel keystroke to undo it again.
  • 3.  RE: Graphite: Storing MiniME banks
    Posted 01-08-2018 15:59
    Thanks for the info -- we will look into trying to re-create this. I know that if you don't have anything selected then it will kick on an ME if you were to "un include" everything. So you do have to have the MiniME enabled before you try to turn off the MEs.
    On a separate note version 1.1 released just before Christmas :) Download and upgrades are here https://www.rossvideo.com/production-switchers/graphite/software/
    But for version 7 XPression you will need to call into tech support for the correct download that matches the version you are running.
