  • 1.  Get Status of ME Bus
    Posted 07-26-2015 16:30
    Is there an ogscript command that can request the from the carbonite what is currently selected on the ME bus?
    On my custom panel in the dashboard, I would like to see the status of what is currently selected in PGM on the bus.
  • 2.  RE: Get Status of ME Bus
    Posted 07-28-2015 12:46
    I do have a grid. file that will give you all the bus outputs to MLE-1. All you have to do is edit the sorce file and change the ip address to match your switcher. If you want the bus's from MLE-2 you just have to change the address of the the the button to match the MLE-2 bus. You can drag and drope any one of the buttons to your panel. Make sure when you drag a button you use (move components) not (select/drag components). If you want the file you can E:Mail me at rjpralle@mbcocala.org.
