  • 1.  Dropdown Data in Dashboard to Xpression
    Posted 10-21-2016 17:05
    Hi I am Working on a Election project in Xpression and need to create a Dashoboard to enter data!! I have a Xpression Scene with 6 Boxes for 6 candidates!! Each Box have a Visual logic setup that if a Change the party name it would change the color of the Box!! But I have 15 candidates What I need is to create a Dashboard to be able to pick from a Dropdown Box the name but when I select the name in the dropbox I need to votes,percent,party name,image path to be updated all at the same time and link the data to Xpression, So If I pick a candidate name, just selecting that name it would get the Votes Data So the Box in Xpression change accordingly! I already have the tha table built in DashBoard the part that I am lost at is what I need to do get the Data From the table and with a Dropdown populate the data in Xpression!! Here's a image of the table that I created and the Dropdowns (the dropdowns are dummy objects for now and for position only at this time) Do I need to put labels with the corresponding data in each Candiate Field? Any help will be very Appreciated!!
    afc
  • 2.  RE: Dropdown Data in Dashboard to Xpression
    Posted 10-21-2016 21:35
    You need to create parameters for the values you actually want to send to XPression
    candidate1.name
    candidate1.votes
    candidate1.anything_else_to_send
    candidate2.name
    candidate2.votes
    candidate2.anything_else_to_send
    candidate3.name
    candidate3.votes
    candidate3.anything_else_to_send
    Then you can add a task to set the values of those parameters based on which candidate is selected.
    params.setValue('candidate1.votes', params.getValue('oid_for_the_votes_parameter', params.getValue('oid_for_the_selection_parameter', 0));
    Does this help?
    James
  • 3.  RE: Dropdown Data in Dashboard to Xpression
    Posted 10-24-2016 15:18
    Hi James and thanks for the Help!! I already have the parameters and their data!! There are in the table and I can Edit the data directly in the table!!
    What I need to do is be able with a Dropdown of the names populate the corresponding Labels so Xpression can update it!!
    candidate1.name
    candidate1.votes
    candidate2.name
    candidate2.votes
    candidate3.name
    candidate3.votes
    Does this help?
    James
  • 4.  RE: Dropdown Data in Dashboard to Xpression
    Posted 10-24-2016 16:02
    So the problem you are having is you don't know how to update the labels under the dropdown list when the dropdown list's selection changes, correct?
    Here is a demo panel that should show you how to do such a thing:
       <meta>
          <params>
             <param access="1" maxlength="0" name="Names" oid="params.names" precision="0" stateless="true" type="STRING_ARRAY" value="Name 1;Name 2;Name 3" widget="default">
                <value>Name 1</value>
                <value>Name 2</value>
                <value>Name 3</value>
             </param>
             <param access="1" maxlength="0" name="Parties" oid="params.parties" precision="0" stateless="true" type="STRING_ARRAY" value="Party 1;Party 2;Party 3" widget="default">
                <value>Party 1</value>
                <value>Party 2</value>
                <value>Party 3</value>
             </param>
             <param access="1" constrainttype="INT_NULL" name="Votes" oid="params.votes" precision="0" stateless="true" type="INT16_ARRAY" value="1;2;3" widget="default"/>
             <param access="1" constrainttype="STRING_CHOICE" name="Table" oid="params.table" precision="0" stateless="true" type="INT16" value="-1" widget="table">
                <constraint>params.names</constraint>
                <constraint>params.parties</constraint>
                <constraint>params.votes</constraint>
             </param>
             <param access="1" maxlength="0" name="XPression Names" oid="xpression.names" precision="0" type="STRING_ARRAY" value="Name 3;Name 3;" widget="label">
                <value>
                </value>
             </param>
             <param access="1" maxlength="0" name="XPression Parties" oid="xpression.parties" precision="0" type="STRING_ARRAY" value="Party 3;Party 3;" widget="label">
                <value>
                </value>
             </param>
             <param access="1" constrainttype="INT_NULL" name="XPression Votes" oid="xpression.votes" precision="0" type="INT16_ARRAY" value="3;3;0" widget="label"/>
             <param access="1" constrainttype="INT_CHOICE" name="XPression Selectors" oid="xpression.selectors" precision="0" type="INT16_ARRAY" value="2;2;-1" widget="default">
                <constraint key="-1">SELECT ONE</constraint>
                <constraint key="0">Name 1</constraint>
                <constraint key="1">Name 2</constraint>
                <constraint key="2">Name 3</constraint>
             </param>
          </params>
          <api>function copyParameters(index)
       var selectedIndex = params.getValue('xpression.selectors', index);
       var nameToUse = '';
       var partyToUse = '';
       var votesToUse = 0;
       if (selectedIndex &gt;= 0)
          nameToUse = params.getValue('params.names', selectedIndex);
          partyToUse = params.getValue('params.parties', selectedIndex);
          votesToUse = params.getValue('params.votes', selectedIndex);
       params.setValue('xpression.names', index, nameToUse);
       params.setValue('xpression.parties', index, partyToUse);
       params.setValue('xpression.votes', index, votesToUse);
    </api>
       </meta>
       <param expand="true" height="483" left="5" oid="params.table" showlabel="false" top="7" width="993"/>
       <table height="249" left="6" style="bg#dark;bdr:etched;" top="498" width="327">
          <tr>
             <param colspan="2" element="0" expand="true" fill="both" insets="2,2,2,2" left="13" oid="xpression.selectors" rowspan="1" runtasksonload="true" showlabel="false" top="501" weightx="1.0" weighty="1.0">
                <task tasktype="ogscript">/*! block id=1000 !*/
    copyParameters(0)
     &lt;block id="1000" type="function_copyParameters" x="10" y="100" w="243" index="0" /&gt;
    /*!!&lt;checksum&gt;709cb77fa54965293d59b588d7407ca6&lt;/checksum&gt;!!*/</task>
             </param>
          </tr>
          <tr>
             <label colspan="1" fill="both" insets="2,2,2,2" name="Name: " rowspan="1" style="txt-align:east" weightx="0.0" weighty="1.0"/>
             <param colspan="1" element="0" expand="true" fill="both" insets="2,2,2,2" oid="xpression.names" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <label colspan="1" fill="both" insets="2,2,2,2" name="Party: " rowspan="1" style="txt-align:east;" weightx="0.0" weighty="1.0"/>
             <param colspan="1" element="0" expand="true" fill="both" insets="2,2,2,2" oid="xpression.parties" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <label colspan="1" fill="both" insets="2,2,2,2" name="Votes: " rowspan="1" style="txt-align:east;" weightx="0.0" weighty="1.0"/>
             <param colspan="1" element="0" expand="true" fill="both" insets="2,2,2,2" oid="xpression.votes" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <button colspan="2" fill="both" insets="2,2,2,2" name="Refresh" rowspan="1" top="501" weightx="1.0" weighty="1.0">
    copyParameters(0)
             </button>
          </tr>
       </table>
       <table height="249" left="340" style="bg#dark;bdr:etched;" top="500" width="327">
          <tr>
             <param colspan="2" element="1" expand="true" fill="both" insets="2,2,2,2" left="13" oid="xpression.selectors" rowspan="1" runtasksonload="true" showlabel="false" top="501" weightx="1.0" weighty="1.0">
                <task tasktype="ogscript">/*! block id=1001 !*/
    copyParameters(1)
     &lt;block id="1001" type="function_copyParameters" x="10" y="100" w="243" index="1" /&gt;
    /*!!&lt;checksum&gt;c8adfab8b853c3fd0492e5fd9cb0aa82&lt;/checksum&gt;!!*/</task>
             </param>
          </tr>
          <tr>
             <param colspan="1" element="1" expand="true" fill="both" insets="2,2,2,2" oid="xpression.names" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <param colspan="1" element="1" expand="true" fill="both" insets="2,2,2,2" oid="xpression.parties" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <param colspan="1" element="1" expand="true" fill="both" insets="2,2,2,2" oid="xpression.votes" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <button buttontype="push" colspan="2" fill="both" insets="2,2,2,2" name="Refresh" rowspan="1" top="501" weightx="1.0" weighty="1.0">
    copyParameters(1)
     &lt;block id="1000" type="function_copyParameters" x="10" y="100" w="243" index="1" /&gt;
    /*!!&lt;checksum&gt;4a92c89c8fdfbbe9b283240a348724c1&lt;/checksum&gt;!!*/</task>
             </button>
          </tr>
       </table>
       <table height="249" left="677" style="bg#dark;bdr:etched;" top="502" width="327">
          <tr>
             <param colspan="2" element="2" expand="true" fill="both" insets="2,2,2,2" left="13" oid="xpression.selectors" rowspan="1" runtasksonload="true" showlabel="false" top="501" weightx="1.0" weighty="1.0">
                <task tasktype="ogscript">/*! block id=1002 !*/
    copyParameters(2)
     &lt;block id="1002" type="function_copyParameters" x="10" y="100" w="243" index="2" /&gt;
    /*!!&lt;checksum&gt;0e3c1fd2bc0663d8b9be5eef10afb494&lt;/checksum&gt;!!*/</task>
             </param>
          </tr>
          <tr>
             <param colspan="1" element="2" expand="true" fill="both" insets="2,2,2,2" oid="xpression.names" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <param colspan="1" element="2" expand="true" fill="both" insets="2,2,2,2" oid="xpression.parties" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <param colspan="1" element="2" expand="true" fill="both" insets="2,2,2,2" oid="xpression.votes" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
    copyParameters(2)
     &lt;block id="1000" type="function_copyParameters" x="10" y="100" w="243" index="2" /&gt;
    /*!!&lt;checksum&gt;aa984189aad6f8147340a852b64952e7&lt;/checksum&gt;!!*/</task>
             </button>
          </tr>
       </table>
    The key part is this piece of code that copies the parameters from the table to the ones you are trying to DataLinq:
    var nameToUse = '';
    var votesToUse = 0;
    if (selectedIndex >= 0)
    Hopefully I have correctly answered your question. If not, please feel free to let me know.
    "‹James
  • 5.  RE: Dropdown Data in Dashboard to Xpression
    Posted 10-24-2016 20:57
    Thanks a LOT James!!! That Works Perfect!!! and it was Exactly what I needed!! I modified the Source code an was able to use it with the names and data that I need it!!!
    One last Thing is what I need to copy or duplicate to get the other paramaters that I need in the Xpression output Labels? I already created the new parameters as you can see in the image!! I just need to added to the in the list of the Dropdown name menu?
    Also How can I copy the Dropdown Tables Because I need 6 candidates and the example is only for 3.
    James Thanks for the GREAT SUPPORT!!!!!
    afc
    "‹James
  • 6.  RE: Dropdown Data in Dashboard to Xpression
    Posted 10-27-2016 22:16
    Hi James!! I was able to add the other fields in the tables and it is changing corresponding to the correct data!! But the problem that I have is when I tried to copy the table to have 6 the copied tables still referencing the old data!!! When I change the name in the dropdown menu all the new copied tables change as well!!!! I tried to edit the visual logic Copy parameters box to a new one and added 3 more lines in the selector parameter and still I get same results in the copied tables!!! How Can I copy the tables and have each one change independently?
    afc
