  • 1.  Dashboard reverse compatible
    Posted 01-11-2018 20:02
    My system uses an older version of Dashboard. Can I create a grid in v.8 and still open that in the older version?
  • 2.  RE: Dashboard reverse compatible
    Posted 01-11-2018 20:42
    That depends on the custom panel. The core of the OGLML code it generates will be the same but certain functions, tags, or features may not be available in an older version.
    We work very hard to maintain forwards-compatibility (a panel created in DashBoard 6.0 MUST work on DashBoard 8.3) but, given that DashBoard is free and publicly-available, we generally expect people to upgrade to the most-recent version to get access to the many new features and improvements we put into each edition.
    Is there a reason why you want to stay with an older version on some systems?
    James
