Somewhat similar issue, my OGX frame just arrived with an IP showing on the lcd screen of 169.254.224.135, the rest of my Ross gear (as shipped) is in the range of 192.168.0.xxx. I am running Dashboard on the built in OS on my Graphite machine. Dashboard can currently see the Control Panel, Graphite... but not the OGX frame. How can I reset the IP of the OGX frame to be in the same range as the rest of the static IPs on the closed network? It seems like using the dip switches will still not put it in the same range as the rest of the gear, and I can't use Dashboard to change it... Thanks!
