  • 1.  Toggle button question
    Posted 12-15-2014 17:26
    Hope this is an easy question...
    Is there an easier way to assign two separate options to a toggle button? Until now, I've been using a choice constraint parameter with the toggle button widget, and then scripting "if this = 1 then do this, if this = 0 then do that"
    Is that the only way, or is there a way to do this in the regular button objects?
  • 2.  RE: Toggle button question
    Posted 12-15-2014 19:19
    That's the recommended way of doing it.
    If you really don't want to use a parameter for it, you can access the `isSelected()` property of the component (though this is not guaranteed to be compatible with all future revisions of DashBoard.
    if (component.isSelected())
    ogscript.debug('Toggle on!');
    else
    ogscript.debug('Toggle off!');
