Hi Kenneth.
createIntChoiceConstraint only works with INT16, INT16_ARRAY, INT32, and INT32_ARRAY parameters. They won't work with STRING and STRING_ARRAY.
If you are choosing from a fixed list, then you should be able to get what you want by changing parameter 0x8 to an integer parameter. You can still get the string value out of the parameter with params.getStrValue(0x8, 0); in ogScript (the string value is also passed to XPression).
If you need the list to be editable, there are ways in DashBoard 6.x to change between different StringChoiceConstraints but no way to create new ones at runtime (there is in DashBoard 7 - available as a beta. Just not in 6.x)
