  • 1.  Imagine/Harris Platinum Router control
    Posted 07-08-2016 18:20
    So I'm still a little new at this, but I'm trying to make a button that will take crosspoints on a Platinum router.
    I can telnet into the router and make routes, but it involves initiating a telnet session, logging in with a username and password, then sending a command in the interface. How would I script this? It would appear as if there needs to be small pauses after entering the username and password for the router to process (half second or so). can I do this with multiple TCP send commands, or would the port close between commands?
  • 2.  RE: Imagine/Harris Platinum Router control
    Posted 07-14-2016 15:12
    I guess maybe the question here is: Is it possible to script a telnet session with DashBoard? I know there are certain negotiation strings that need to be sent, It's not just as simple as sending TCP strings to port 23.
  • 3.  RE: Imagine/Harris Platinum Router control
    Posted 07-26-2016 22:44
    You might have an easier time dealing with the Harris XY or LRC ethernet protocol than trying to simulate a telnet session. I think I have the documents on that somewhere, or you could try and contact Imagine to get the docs on those.
