DashBoard has added a number of new features to version 8.3.1, which is now available for download at
https://www.rossvideo.com/control-systems/dashboard/products/dashboard/#download.
I personally think that the USB joystick control of PIVOTCams that was introduced (as long as you update your PIVOTCam Camera Panel software to version 1.1) really helps to make that whole offering really attractive... great quality camera for a low price that can now be controlled using an off the shelf USB joystick.
We added in NDI™ video integration. There is a new NDI button in the Edit Mode window when you enter PanelBuilder Edit Mode. Choose it, draw the video box on the screen and enter in the requested information. You need to be feeding it an NDI™ source, and that is supported in Ross XPression.
Widget configuration options are available by manually adding them to custom panels. This feature was available previously, but unless you knew it was there and how to use it, few were not to take advantage of it.
Other bug fixes can be identified in the Release Notes available at the same place as you download the latest version of DashBoard.
If you are running DashBoard v8.3 you should update to v8.3.1 as we fixed a bug to ensure listeners are always called when updates to individual array values happen in rapid succession and a couple of other quick fixes.
