  • 1.  getIdentifiedConstraint
    Posted 06-12-2015 07:44
    Hi
    I am trying to use getIdentifiedConstraint and getConstraint to get information about the constraints of a parameter. The ogScript-documentation is very scarce on information about these functions.
    To take my problem for instance:
    I have a integer-parameter with several constraints. It looks like this:
    Value: 1 Name: abc
    Value: 2 Name: xyz
    I know the value I need to find within these constraints. What I am looking for is the "Name" of that value. I would think like this, but of course it doesn't work:
    var value = this.getValue(); // Don't worry about how I know this
    var allMyChoices = params.getConstraint (0x15);
    var MySingeChoice = allMyChoices.getIdentifiedConstraint (value);
    var myName = MySingleChoice.getValueAsString();
    I know it may be hard to understand what I am trying to accomplish here, but a brief overview of how the constraint-scripting works would be appreciated :)
  • 2.  RE: getIdentifiedConstraint
    Posted 06-12-2015 19:50
    var myStringValue = this.getValueAsString(); //Okay, but did you know you could just do this?
    //If you're still curious, here's the answer to your question
    var allMyChoices = params.getConstraint(0x15);
    var myChoiceName = allMyChoices.getStringOf(value);
  • 3.  RE: getIdentifiedConstraint
    Posted 06-12-2015 19:55
    You can also get the full list of choices with:
    var choices = allMyChoices.getChoices();
    for (var i = 0; i < choices.length; i++)
    ogscript.debug(choices[i].getValue() + ' = ' + choices[i].getName());
