  • 1.  Camera Color Control/Color Correcting With Dashboard
    Posted 07-26-2016 14:02
    I know that with Ross' new Acid Cameras that there is a panel in Dashboard that allows for the operator to manage the coloring of the camera such as white balance, but is there a way to make a panel in Dashboard that makes it to where you can color correct other cameras? I'm trying to color correct a small POV camera that doesn't have an adjustable white balance.
  • 2.  RE: Camera Color Control/Color Correcting With Dashboard
    Posted 08-02-2016 15:09
    Unfortunately, no. Not with the specific panel DashBoard uses to modify the paint settings on the ACID cameras as it is unlikely that your POV camera speaks the same protocol.
    If you know or have access to the protocol our small POV camera speaks, it *may* be possible for you to create a CustomPanel to adjust some of the paint parameters on it but that would depend heavily on what protocol your camera speaks and which parameters it exposes.
  • 3.  RE: Camera Color Control/Color Correcting With Dashboard
    Posted 08-03-2016 19:31
    It would seem if the camera does not have an adjustable white balance, there is most likely no command set for color correcting on that camera.
