Hi Andrew.
The panel should automatically be showing a parameter value as it updates. How are you updating your values?
If you can post your panel back (use the "#" button in the toolbar of this forum to post code), I'll gladly take a look at what is going on. You almost certainly won't need F5 or any kind of full refresh to achieve what you're after.
Cheers.
James
