  • 1.  Listener toggle button
    Posted 01-18-2019 12:54
    Probably an easy answer, but yeah... When creating a listener, you have the option of checking a box that says "show start/stop toggle button"...
    Uhm...
    What happens to this button? Where is it?
    <abs contexttype="opengear" gridsize="20" id="_top">
    <meta>
    <listener autostart="false" buttontype="toggle" listenport="9876" maxlength="1024" name="listener1" udp="true"/>
    </meta>
  • 2.  RE: Listener toggle button
    Posted 01-18-2019 14:45
    If you take it out of the tag, you will see it and be able to style/size/position it. The problem is that the tag is guaranteed to never actually return any user interface components.
    James
