  • 1.  Closing Grids with Panel Links
    Posted 04-01-2019 12:57
    I am a relatively new user of Dashboard and I was wondering if there was anyway to code into a panel link to close the grid that it is switching from. For example, press a panel switch on Grid A to take you to Grid B and this then closes the Grid A.
    Thanks in advance.
  • 2.  RE: Closing Grids with Panel Links
    Posted 04-02-2019 22:17
    Hi Harvey.
    The feature you are looking for will be in the next release of DashBoard. Instead of using an <ext/> tag (external link), you will want to use the updated <exit/> tag and specify the "openpanelid" attribute:
    <exit level="panel" openobjectid="PANEL TO OPEN" prompt="Exit?" name="Launch Other Panel"/>
    We don't presently have a beta available - the <exit/> tag with a level of "panel" is in the current version but the support for "openobjectid" will not be available until 8.6.
    James
