I am trying to build a dashboard to control the display of a baseball GIP on a videoboard.
I'd like to display the batting orders as a list of toggle buttons. Unfortunately I am having trouble setting the parameter constraints through scripting.
I started with the example shared in this post, which seemed to work. https://discussions.rossvideo.com/fo...8156#post18156
Building off of that, I tried to generate the list of constraints from a statcrew XML. Copious amounts of ogscript.debug proves that I have extracted the correct data from the XML, but I am unable to set the constraint correctly.
I am expecting the constraint to look like the following:
| 36 |
Bob Smith |
| 28 |
John Doe |
| 2 |
Alice Bob |
Instead, it winds up looking like this:
| 0 |
[object Object] |
| 1 |
[object Object] |
| 2 |
[object Object] |
My dashboard panel is below. Any idea what I'm screwing up?
<abs contexttype="opengear" gridsize="20" style="">
<meta>
<params>
<param access="1" constrainttype="INT_CHOICE" name="Home Players" oid="homePlayers" precision="0" type="INT16" value="0" widget="radio-toggle">
<constraint key="0">[object Object]</constraint>
<constraint key="1">[object Object]</constraint>
<constraint key="2">[object Object]</constraint>
<constraint key="3">[object Object]</constraint>
<constraint key="4">[object Object]</constraint>
<constraint key="5">[object Object]</constraint>
</param>
<param access="1" maxlength="0" name="Stat Crew Path" oid="stat_crew_path" type="STRING" value="file:/c:/Users/Bob/Desktop/base.xml" widget="default"/>
</params>
</meta>
<button buttontype="push" height="60" left="340" name="Alice and friends" top="260" width="120">
<task tasktype="ogscript">var choiceArray = [];
var numbers = [1, 5, 10];
var names = ["Alice", "Bob", "Susan"];
for (var x = 0; x < numbers.length; x++) {
choiceArray.push({"key":numbers[x], "value":names[x]});
ogscript.debug("Added " + numbers[x] + " " + names[x]);
var choiceConstraint = params.createIntChoiceConstraint(choiceArray);
params.replaceConstraint("homePlayers", choiceConstraint);</task>
</button>
<table height="980" left="820" maxperrow="1" top="80" width="200">
<tr>
<param colspan="1" expand="true" fill="both" oid="homePlayers" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
</tr>
</table>
<button buttontype="push" height="120" left="200" name="Refresh Home" top="260" width="140">
<task tasktype="ogscript">var numbers = [];
var names = [];
var rss = ogscript.parseXML(params.getValue('stat_crew_path', 0));
if (rss != null) {
var playerList = ogscript.runXPath("/bsgame/team[@vh='H']/player[not(@name='TEAM')]", rss);
for (var x = 0; x < playerList.length; x++) {
numbers.push(playerList.item(x).getAttribute("uni"));
names.push(playerList.item(x).getAttribute("name"));
//var numbers = [1, 5, 10];
//var names = ["Alice", "Bob", "Susan"];
for (var x = 0; x < numbers.length && x < 3; x++) {
choiceArray.push({key:numbers[x], value:names[x]});
</button>
<button buttontype="push" height="60" left="340" name="Lots of bobs" top="320" width="120">
for (var x = 0; x < 80; x++) {
choiceArray.push({"key":x, "value":"bob"});
</button>
