It might be a lot easier to use a structured parameter rather than trying to dynamically change the size of a table in a panel. There are no commands I'm aware of that will add or remove columns.
Attached is an example panel that uses a structured parameter.
EDIT: I tried to attach it, but the forum won't let me. Here is the content, copy and paste it to a .grid file:
<meta>
<params>
<param access="1" constrainttype="STRUCT" name="Clip Info" oid="templates.clipInfo" structtype="com.rossvideo.playinfo" type="STRUCT" widget="36">
<value>
<subparam access="1" maxlength="0" name="Clip Name" suboid="ClipName" type="STRING" value="Test" widget="0"/>
<subparam access="1" maxlength="0" name="Director" suboid="Director" type="STRING" value="Test" widget="0"/>
<subparam access="1" maxlength="0" name="Original Air Date" suboid="OriginalAirDate" type="STRING" value="Test" widget="0"/>
<subparam access="1" maxlength="0" name="Author" suboid="Author" type="STRING" value="Test" widget="0"/>
</value>
</param>
<param access="1" constrainttype="STRUCT" name="Clip List" oid="params.clipList" structtype="com.rossvideo.clipinfo" templateoid="templates.clipInfo" type="STRUCT_ARRAY" widget="36">
<value>
<subparam suboid="ClipName" value="Winter is Coming"/>
<subparam suboid="Director" value="Tim Van Patten"/>
<subparam suboid="OriginalAirDate" value="April 24, 2011"/>
<subparam suboid="Author" value="David Benoiff & D.B. Weiss"/>
</value>
<value>
<subparam suboid="ClipName" value="The Kingsroad"/>
<subparam suboid="Director" value="Brian Kirk"/>
</value>
<value>
<subparam suboid="ClipName" value="Lord Snow"/>
<subparam suboid="OriginalAirDate" value="May 1, 2011"/>
</value>
<value>
<subparam suboid="ClipName" value="Cripples, Bastards, and Broken Things"/>
<subparam suboid="OriginalAirDate" value="May 8, 2011"/>
<subparam suboid="Author" value="Bryan Cogman"/>
</value>
<value>
<subparam suboid="ClipName" value="A Golden Crown"/>
<subparam suboid="Director" value="Daniel Minahan"/>
<subparam suboid="OriginalAirDate" value="May 22, 2011"/>
<subparam suboid="Author" value="David Benioff & D. B. Weiss"/>
</value>
</param>
<param access="1" constrainttype="INT_NULL" name="Selection" oid="Selection" precision="0" strvalue="5" type="INT32" value="5" widget="100"/>
</params>
</meta>
<param constrainttype="STRING_CHOICE" element="0" height="324" left="39" oid="params.clipList" precision="0" top="207" width="699">
<config key="w.alwaysscroll">true</config>
<config key="w.selectionparam">Selection</config>
<constraint>ClipName</constraint>
<constraint>Director</constraint>
</param>
<button buttontype="push" height="62" left="45" name="Insert" top="543" width="237">
<task tasktype="ogscript">
var newValue = { ClipName: "", Director: "", OriginalAirDate: "", Author: "" } var p = params.getParam('params.clipList', 0); p.setValueAt(p.getElementCount(), newValue);
</task>
</button>
<param expand="true" height="103" left="78" oid="Selection" style="bdr:etched;bg#dark;font:bold;size:Biggest;o #000000;fg#FFFFFF;txt-align:center;" top="42" width="420"/>
<button buttontype="push" height="51" left="307" name="Delete" top="547" width="162">
var selection = params.getValue('Selection', 0); if (selection < 0) { return; } var newValue = new Array(); var clipList = params.getParam('params.clipList', 0); for (var i = 0; i < clipList.getElementCount(); i++) { if (i != selection) { newValue.push(clipList.getValueAt(i)); } } params.setAllValues('params.clipList', newValue);
</task>
</button>
