You need to do an asyncPost feeding the URL of the file on your file system and then just feed the result to JSON.parse.
An example of the script can be found in the following grid.
<abs contexttype="opengear" id="_top">
<meta>
<params>
<param access="1" maxlength="0" name="Data URL" oid="Data_URL" stateless="true" type="STRING" value="" widget="text"/>
<param access="1" name="Structured Data" oid="struct-data" stateless="true" type="STRUCT_ARRAY" widget="table">
<value>
<subparam access="1" maxlength="0" name="name" suboid="team" type="STRING" value="" widget="default"/>
</value>
</param>
</params>
</meta>
<param expand="true" height="61" left="248" oid="Data_URL" right="17" top="20">
<task tasktype="ogscript">
function callback(resultStr)
if (resultStr != null)
var json = JSON.parse(resultStr);
var a = null;
if (Array.isArray(json))
a = json;
} else {
a = [];
a.push(json);
params.setAllValues('struct-data', a);
params.resetAllValues('struct-data');
ogscript.asyncPost(params.getValue('Data_URL', 0), null, callback);</task>
</param>
<param bottom="10" expand="true" left="19" oid="struct-data" right="9" showlabel="false" top="94"/>
<label height="38" left="18" name="File URL: " style="txt-align:east" top="29" width="223"/>
To test the grid you can feed a .json file with the following sample data:
"name":"John",
"age":30,
"cars": {
"car1":"Ford",
"car2":"BMW",
"car3":"Fiat"
"name":"Dave",
"age":25,
"cars": {
"car1":"Toyota",
"car2":"Jeep"
"name":"Helen",
"age":20,
"cars": {
"car1":"Honda"
"name":"Tyler",
"age":34,
"cars": {
"car1":"Ford",
"car2":"Toyota"
}]#DashBoard
