  • 1.  Widget missing after upgrading Dashboard
    Posted 04-04-2019 17:40
    Hello, after upgrading Dashboard to the latest version, some of the pre-built widgets seem to be gone. Are they in a different place? I'm interested in the widget that embeds a video feed. I only see an Xpression widget and an ogScript Macro widget now after updating.
  • 2.  RE: Widget missing after upgrading Dashboard
    Posted 04-04-2019 18:16
    Hi Gene.
    Those are the only 2 widgets that ship as part of DashBoard. If you had other widgets, they would have been added to the [DashBoard Directory]/widgets folder manually, live in a widgets folder beside a CustomPanel, or are served-up from a DashBoard Connect device.
    Are you sure you aren't thinking of the NDI video window that is part of the standard CustomPanel toolbar?
  • 3.  RE: Widget missing after upgrading Dashboard
    Posted 04-04-2019 18:43
    Hi James,
    I believe it was just a plain install of the previous version but I am new to Dashboard so I may be thinking of something else or was looking at a different custom panel. I'll keep looking around for it! Thanks.
