Update 2020-08-24:
Hi <x-zendesk-user data-user-name="Christopher Chappel">389100439691</x-zendesk-user> and <x-zendesk-user data-user-name="Matthew Drury">369629166932</x-zendesk-user>
I just wanted to let you both know that DashBoard 9.1.2 was released today and addresses the issue of card slot names being sent via the proxy server.
To take advantage of this improvement, you can simply upgrade your proxy server DashBoard. The client DashBoard machines will automatically start getting the slot names once you upgrade the proxy server regardless of the detail level specified in the DashBoard.ini. We still recommend updating the client machines to the latest release when you can.
With "minimal mode" now available to you, you should notice faster device device loading times and decreased network traffic for your client machines.
Cheers
James
