  • 1.  Dashboard Web Browser Frame
    Posted 05-27-2020 19:02
    Is there a way to have a web browser frame automatically log in to a web page on a machine that requires a login?  I've tried the deprecated method of http://<username>:<password>@<ipaddress> - but kinda expected it to fail - and it did.
    Instead I was wondering if there is a way to pass the security credentials in properly?
  • 2.  RE: Dashboard Web Browser Frame
    Posted 06-01-2020 15:52
    What platform are you on?   It appears to work for us when using the browser tag in Windows.
  • 3.  RE: Dashboard Web Browser Frame
    Posted 06-01-2020 16:07
    Are you saying you can get the login to work with http://<username>:<password>@<ipaddress>?
    I'm running DB9 on Windows 10 (1909).
  • 4.  RE: Dashboard Web Browser Frame
    Posted 06-01-2020 17:09
    Hi Dan
    I tested it against my home router's configuration page (which has a prompt for username/password) and, on Windows 10 using the <browser/> tag, was able to get it to work with the username/password embedded in the URL.
    James
  • 5.  RE: Dashboard Web Browser Frame
    Posted 06-01-2020 18:59
    Ultimately its up to the developer of the website whether that's allowed or not.
  • 6.  RE: Dashboard Web Browser Frame
    Posted 06-01-2020 20:00
    Yes - just did a little research and indeed you are correct.  Thank you - this set me straight!
