I have several Take Items in a Sequence, and would like to make some DashBoard buttons that would make selection changes for options that were set up with User Input Controls. For example, if user selected options are THIS and THAT, is it possible to make DashBoard buttons so that a user can remotely change the selection from THIS to THAT, or vice-versa?
If so, what are the items I would need to access via code? What is the syntax needed to access the list of user input items, and make/change the current selection?
Thanks,
Shane Finley
