To change the color of a button, you need to set its style.
Let's assume feedback you get from the Arduino is a string, you can then set the style of your button (e.g. coloredButton) based on the string value to color red like this:
ogscript.setStyle('coloredButton', 'bg#ff0000');
The following example grid allows you to choose the color you want to assign to the button using a drop down list provided by a local parameter:
<meta>
<params>
<param access="1" constrainttype="STRING_CHOICE" maxlength="0" name="msgParam" oid="msgParam" type="STRING" value="blue" widget="combo">
<constraint>green</constraint>
<constraint>red</constraint>
<constraint>blue</constraint>
</param>
</params>
</meta>
<param expand="true" height="78" left="305" oid="msgParam" top="101" width="253">
<task tasktype="ogscript">var text = params.getValue('msgParam', 0);
switch (text){
case 'green':
ogscript.setStyle('coloredButton', 'bg#009933');
break;
case 'red':
break;
case 'blue':
ogscript.setStyle('coloredButton', 'bg#0099ff');
break;
}</task>
</param>
<button buttontype="push" height="79" id="coloredButton" left="81" name="Colored Button" top="104" width="148"/>
