Hi James,
I think that has got it sussed, Thank you very much
I believe that this is all up and running if anyone else wants to test/have a play with it, as I think I've proved it as far as I can for the moment. You will need to add your NK ID into the nk-router abs context.
I hope this is useful to people.
Usage:
Select Router Type (to calculate the number of crosspoints to process)
Enter a Name
Click Save in the slot where you would like to save your Snapshot (if this appears to do nothing, then there is no connection to the router)
Clcik Restore to Restore a Snapshot.
Click Clear to delete the snapshot.
If you Lock a Snapshot, then you cannot Save over it or Clear it. There is no restriction on restoring a snapshot at any time.
Current Limitations:
It only saves and restores Layer 0 (MD Vid as standard)
You must save the grid file, otherwise your snapshots will not be preserved in the event of a power loss.
There is no double check that you want to restore a snapshot, it just does it.
<abs contexttype="opengear">//Code Written by James Sladen, code@james.sladen.org, with help from James Peltzer from Ross. v1.2<meta>
<api>function debug(str)
ogscript.debug(str);
}</api>
<params>
<param access="1" constraint="-1.0;144.0;-1.0;144.0;1" constrainttype="INT_STEP_RANGE" name="0x101 Snapshot_1_Data" oid="0x101" precision="0" type="INT16_ARRAY" value="-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1" widget="default"/>
<param access="1" constraint="-1.0;144.0;-1.0;144.0;1" constrainttype="INT_STEP_RANGE" name="0x102 Snapshot_2_Data" oid="0x102" precision="0" type="INT16_ARRAY" value="-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1" widget="default"/>
<param access="1" constraint="-1.0;144.0;-1.0;144.0;1" constrainttype="INT_STEP_RANGE" name="0x103 Snapshot_3_Data" oid="0x103" precision="0" type="INT16_ARRAY" value="-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1" widget="default"/>
<param access="1" constraint="-1.0;144.0;-1.0;144.0;1" constrainttype="INT_STEP_RANGE" name="0x104 Snapshot_4_Data" oid="0x104" precision="0" type="INT16_ARRAY" value="-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1" widget="default"/>
<param access="1" constraint="-1.0;144.0;-1.0;144.0;1" constrainttype="INT_STEP_RANGE" name="0x105 Snapshot_5_Data" oid="0x105" precision="0" type="INT16_ARRAY" value="-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1" widget="default"/>
<param access="1" constraint="-1.0;144.0;-1.0;144.0;1" constrainttype="INT_STEP_RANGE" name="0x106 Snapshot_6_Data" oid="0x106" precision="0" type="INT16_ARRAY" value="-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1" widget="default"/>
<param access="1" constraint="-1.0;144.0;-1.0;144.0;1" constrainttype="INT_STEP_RANGE" name="0x107 Snapshot_7_Data" oid="0x107" precision="0" type="INT16_ARRAY" value="-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1" widget="default"/>
<param access="1" constraint="-1.0;144.0;-1.0;144.0;1" constrainttype="INT_STEP_RANGE" name="0x108 Snapshot_8_Data" oid="0x108" precision="0" type="INT16_ARRAY" value="-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1" widget="default"/>
<param access="1" constraint="-1.0;144.0;-1.0;144.0;1" constrainttype="INT_STEP_RANGE" name="0x109 Snapshot_9_Data" oid="0x109" precision="0" type="INT16_ARRAY" value="-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1" widget="default"/>
<param access="1" constraint="-1.0;144.0;-1.0;144.0;1" constrainttype="INT_STEP_RANGE" name="0x100 Snapshot_0_Data" oid="0x100" precision="0" type="INT16_ARRAY" value="-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1;-1" widget="default"/>
<param access="1" maxlength="0" name="0x80 Save_Snapshot_As" oid="0x80" type="STRING" value="Test 0" widget="default"/>
<param access="1" constrainttype="INT_CHOICE" name="0x70 Router Type" oid="0x70" precision="0" type="INT16_ARRAY" value="72" widget="default">
<constraint key="4">NK-3G164</constraint>
<constraint key="16">NK-3G16</constraint>
<constraint key="32">NK-3G32</constraint>
<constraint key="34">NK-3G34</constraint>
<constraint key="64">NK-3G64</constraint>
<constraint key="72">NK-3G72</constraint>
<constraint key="144">NK-3G144-X</constraint>
</param>
<param access="1" maxlength="0" name="0x89 Snapshot Names" oid="0x89" precision="0" type="STRING_ARRAY" value="[Empty];[Empty];[Empty];[Empty];[Empty];[Empty];[Empty];[Empty];[Empty];[Empty]" widget="default">
<value>[Empty]</value>
</param>
<param access="1" maxlength="0" name="0x88 Last Action" oid="0x88" type="STRING" value="Snapshot 0: Cleared" widget="default"/>
<param access="1" constrainttype="INT_CHOICE" name="0x87 Snapshots_locked" oid="0x87" precision="0" type="INT16_ARRAY" value="0;0;0;0;0;0;0;0;0;0" widget="default">
<constraint key="0">Unlocked</constraint>
<constraint key="1">Locked</constraint>
</param>
</params>
</meta>
<abs bottom="0" contexttype="nk-router" left="0" objectid="INSERT NK ID HERE" right="0" top="0">
<api>function SaveSnapshot(Index)
if (params.getValue(0x87,Index) == 1)
params.setValue(0x88,0,"Snapshot "+Index+": Is Locked, NOT SAVING");
else
for (save_count = 0; save_count <= (params.getValue(0x70, 0) -1); save_count = save_count + 1)
params.setValue((0x100+Index),save_count,nk.getStatus((save_count + 1),1));
params.setValue(0x89,Index,params.getValue(0x80,0));
params.setValue(0x88,0,"Snapshot "+Index+": Saved As: "+params.getValue(0x80,0));
function RestoreSnapshot(Index)
function SlowLoad()
for (load_count = 0; load_count <= (params.getValue(0x70, 0) -1); load_count = load_count + 1)
nk.doSwitch(load_count,(params.getValue(0x100+Index,load_count)-1),1);
ogscript.pause(100);
params.setValue(0x88,0,"Snapshot "+Index+": Restoring XPT:"+(load_count+1)+" SRC: "+(params.getValue(0x100+Index,load_count)));
params.setValue(0x88,0,"Snapshot "+Index+": Restored");
ogscript.asyncExec(SlowLoad);
function ClearSnapshot(Index)
params.setValue(0x88,0,"Snapshot "+Index+": Is Locked, NOT CLEARING");
else
for (reset_count = 0; reset_count <= 143; reset_count = reset_count + 1)
params.setValue(0x100+Index,reset_count,-1);
params.setValue(0x89,Index,"[Empty]");
params.setValue(0x88,0,"Snapshot "+Index+": Cleared");
}</api>
<param expand="true" height="90" left="220" oid="0x70" right="10" style="style:toggleButton" top="20" widget="22"/>
<label height="90" left="10" name="Select Router Type" style="txt-align:west" top="10" width="200"/>
<param expand="true" height="60" left="220" oid="0x80" top="125" widget="3" width="300"/>
<label height="60" left="10" name="Save Snapshot As" style="txt-align:west" top="125" width="200"/>
<param expand="true" height="60" left="10" oid="0x89" right="10" style="style:toggleButton" top="200" widget="22"/>
<label height="60" left="550" name="Last Action" style="txt-align:west" top="125" width="100"/>
<param expand="true" height="60" left="680" oid="0x88" right="10" top="125" widget="1"/>
<simplegrid bottom="10" height="60" left="10" style="bg#dark;bdr:etched;" width="470">
<ipslist style="t:bg#timerfg;f:bg#FF0000;"/>
</simplegrid>
<table height="280" left="10" right="10" top="260">
<tr>
<button buttontype="push" colspan="1" fill="both" name="Save 0" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">SaveSnapshot(0);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Save 1" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">SaveSnapshot(1);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Save 2" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">SaveSnapshot(2);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Save 3" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">SaveSnapshot(3);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Save 4" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">SaveSnapshot(4);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Save 5" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">SaveSnapshot(5);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Save 6" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">SaveSnapshot(6);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Save 7" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">SaveSnapshot(7);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Save 8" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">SaveSnapshot(8);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Save 9" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">SaveSnapshot(9);</task>
</button>
</tr>
<tr>
<button buttontype="push" colspan="1" fill="both" name="Restore 0" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">RestoreSnapshot(0);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Restore 1" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">RestoreSnapshot(1);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Restore 2" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">RestoreSnapshot(2);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Restore 3" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">RestoreSnapshot(3);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Restore 4" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">RestoreSnapshot(4);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Restore 5" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">RestoreSnapshot(5);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Restore 6" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">RestoreSnapshot(6);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Restore 7" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">RestoreSnapshot(7);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Restore 8" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">RestoreSnapshot(8);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Restore 9" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">RestoreSnapshot(9);</task>
</button>
</tr>
<tr>
<button buttontype="push" colspan="1" fill="both" name="Clear 0" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">ClearSnapshot(0)</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Clear 1" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">ClearSnapshot(1)</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Clear 2" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">ClearSnapshot(2)</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Clear 3" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">ClearSnapshot(3)</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Clear 4" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">ClearSnapshot(4)</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Clear 5" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">ClearSnapshot(5)</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Clear 6" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">ClearSnapshot(6)</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Clear 7" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">ClearSnapshot(7)</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Clear 8" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">ClearSnapshot(8)</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Clear 9" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">ClearSnapshot(9)</task>
</button>
</tr>
<tr>
<param colspan="1" element="0" expand="true" fill="both" oid="0x87" rowspan="1" showlabel="false" style="t:bg#FB0000;f:bg#000000;" weightx="1.0" weighty="1.0" widget="toggle"/>
<param colspan="1" element="1" expand="true" fill="both" oid="0x87" rowspan="1" showlabel="false" style="t:bg#FB0000;f:bg#000000;" weightx="1.0" weighty="1.0" widget="toggle"/>
<param colspan="1" element="2" expand="true" fill="both" oid="0x87" rowspan="1" showlabel="false" style="t:bg#FB0000;f:bg#000000;" weightx="1.0" weighty="1.0" widget="toggle"/>
<param colspan="1" element="3" expand="true" fill="both" oid="0x87" rowspan="1" showlabel="false" style="t:bg#FB0000;f:bg#000000;" weightx="1.0" weighty="1.0" widget="toggle"/>
<param colspan="1" element="4" expand="true" fill="both" oid="0x87" rowspan="1" showlabel="false" style="t:bg#FB0000;f:bg#000000;" weightx="1.0" weighty="1.0" widget="toggle"/>
<param colspan="1" element="5" expand="true" fill="both" oid="0x87" rowspan="1" showlabel="false" style="t:bg#FB0000;f:bg#000000;" weightx="1.0" weighty="1.0" widget="toggle"/>
<param colspan="1" element="6" expand="true" fill="both" oid="0x87" rowspan="1" showlabel="false" style="t:bg#FB0000;f:bg#000000;" weightx="1.0" weighty="1.0" widget="toggle"/>
<param colspan="1" element="7" expand="true" fill="both" oid="0x87" rowspan="1" showlabel="false" style="t:bg#FB0000;f:bg#000000;" weightx="1.0" weighty="1.0" widget="toggle"/>
<param colspan="1" element="8" expand="true" fill="both" oid="0x87" rowspan="1" showlabel="false" style="t:bg#FB0000;f:bg#000000;" weightx="1.0" weighty="1.0" widget="toggle"/>
<param colspan="1" element="9" expand="true" fill="both" oid="0x87" rowspan="1" showlabel="false" style="t:bg#FB0000;f:bg#000000;" weightx="1.0" weighty="1.0" widget="toggle"/>
</tr>
</table>
