  • 1.  Roll Clip button map to Dashboard?
    Posted 04-22-2019 15:42
    Can the Roll Clip button on a Carbonite switcher be mapped to trigger an event in Dashboard? Looking to control a web-based playback server.
    Thanks,
    Gene
  • 2.  RE: Roll Clip button map to Dashboard?
    Posted 04-22-2019 21:23
    You are better off taking the Roll Clip button from the ViewControl screen instead of the virtual panel as it is a simple toggle button. The buttons on the virtual panels are a little more difficult to interact with.
    If you drag this Roll Clip button to a custom panel, you can attach a task to it to run whenever the button changes state - just drag it onto a custom panel, go into edit mode in your panel, and attach a task to do whatever action you want.
    Cheers.
    James
  • 3.  RE: Roll Clip button map to Dashboard?
    Posted 04-23-2019 15:14
    Thanks James!
