  • 1.  Copy and edit existing panel
    Posted 09-08-2016 00:19
    I'd like to modify the View Control panel. Is there a way to copy the existing view control panel so that I can make some edits?
  • 2.  RE: Copy and edit existing panel
    Posted 09-08-2016 13:58
    There are several ways to do this. The easiest one involves the following:
    1. Create a new blank Custom Panel.
    2. Open ViewControl in one window and the Custom Panel in another window.
    3. Put ViewControl into "Edit Mode" (CTRL + G) and drag the entire UI into your Custom Panel (start your drag on the gap between the custom control buttons on and the output displays to get the bottom layer)
