Hi Jeff,
<312> will be encoded to <312> but this should still send encoded chars and you should get <312> on the other side.
I've created a quick example for you to test UDP sending and receiving. You will need to have two instance of DashBoard running to do this which on windows is relatively straight forward, if you navigate to the DashBoard.exe double click on it to open it then repeat to open another instance.
If you create a new panel and paste the following code in, this will be your sender panel, I have included your code example in visiual logic and also one using ogscript alone. I have also hooked up two params to allow you to change the host and port at runtime.
<meta>
<params>
<param access="1" maxlength="0" name="host" oid="host" type="STRING" value="127.0.0.1" widget="default"/>
<param access="1" constraint="80.0;99999.0;80.0;99999.0;1" constrainttype="INT_STEP_RANGE" name="port" oid="port" precision="0" type="INT32" value="27001" widget="default"/>
</params>
</meta>
<button buttontype="push" height="164" left="16" name="Visual Logic Test" top="165" width="190">
<task tasktype="ogscript">/*! block id=1012,1014,1015 !*/
ogscript.sendUDPString(params.getValue('host', 0), params.getValue('port', 0), "&lt;312&gt;");
<block id="1012" type="ogscript_sendudpasstring" x="464" y="251" w="318" HOST="ID:1014" PORT="ID:1015" STRING="&amp;lt;312&amp;gt;" />
<block id="1014" type="param__top&amp;host (host)[0]" x="137" y="188" w="243" SET="" />
<block id="1015" type="param__top&amp;port (port)[0]" x="139" y="279" w="243" SET="" />
/*!!<checksum>b2867cb777b710acabe3328247b60179</checksum>!!*/</task>
</button>
<button buttontype="push" height="164" left="18" name="Ogscript Test" top="337" width="190">
<task tasktype="ogscript">var sendToHost = params.getValue( "host", 0 );
var sendToPort = params.getValue( "port", 0 );
ogscript.debug( "HOST: " + sendToHost + " : " + sendToPort );
ogscript.sendUDPString(sendToHost, sendToPort, "&lt;312&gt;");</task>
</button>
<table height="134" left="16" style="bg#tabbg;" top="19" width="439">
<tr>
<label colspan="1" fill="both" insets="4,4,4,4" name="Host" rowspan="1" style="txt-align:east;" weightx="1.0" weighty="1.0"/>
<param colspan="1" expand="true" fill="both" oid="host" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
</tr>
<tr>
<label colspan="1" fill="both" insets="4,4,4,4" name="Port" rowspan="1" style="txt-align:east;" weightx="1.0" weighty="1.0"/>
<param colspan="1" expand="true" fill="both" oid="port" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
</tr>
</table>
And in the other instance of DashBoard create anther panel which will be your receiver and paste in the following code:
<meta>
<params>
<param access="1" maxlength="0" name="received" oid="received" type="STRING" value="" widget="default"/>
</params>
</meta>
<meta>
<listener autostart="true" listenport="27001" maxlength="1024" udp="true">
<task tasktype="ogscript">ogscript.debug( "Got a UDP message: " + event.getBytesAsString() );
params.setValue( "received", 0, event.getBytesAsString() );</task>
</listener>
</meta>
<param expand="true" height="113" left="33" oid="received" showlabel="false" top="56" width="330"/>
This will allow you to test the UDP message is being sent and received and also check the format that's being sent.
Let me know how you get on and if this works. If the receiver is working then you can try hooking this into your lighting and see if that works.
I hope this helps.
Colin.
