Has anyone tried to add an NDI source from a VLC NDI stream? I have googled a few different things but have been unsuccessful.
If you have already checked that the NDI source can be viewed using an NDI Monitor on the same platform you are running Dashboard, then it should work. If you cant view it in the NDI Monitor then it wont work in Dashboard. If this is the case its likely you have networking or firewall issues.
If you can view it in an NDI Monitor but not in Dashboard, that would be a surprise and something you would need to investigate further.
